System: K-9 Mail v3.404 / Liberty v1.0 / Droid X
Sorry in advance for any confusion! This worked for me! It shouldn't be this hard!
My LED wasn't flashing at all for new mail for either of the two accounts I set up in K-9.
I don't think I had the problem before moving to Liberty.
I reinstalled K-9 from the Market, and suddenly LED notification was working for *one* of the accounts.
Well, the colors were different on the Color Picker Palette, so I decided to try and get the *same* color on the non-working account as on the working account.
Two options: Either use the Color Picker in K-9 to approximate the "right" color by touch, or modify the preferences database.
Here's how I did the second choice:
1) Using Root Explorer (or some such) check out the the database /data/data/com.fsck.k9/databases/preferences_storage
2) Make note of the key pair like 'YOUR_ACCOUNT_SPEC.ledColor' = 'YOUR_LED_COLOR_SPEC'
For me, these were crazy values like YOUR_ACCOUNT_SPEC = 'cfbe1c53-322f-41db-bc96-2cd83bbb838a' and YOUR_LED_COLOR_SPEC = '-15043477'
3) Using your PC:
Code:
$ adb pull /data/data/com.fsck.k9/databases/preferences_storage
$ cp preferences_storage preferences_storage.backup # In case I do bad things!
$ sqlite3 preferences_storage "update preferences_storage set value='-15043477' where primkey='cfbe1c53-322f-41db-bc96-2cd83bbb838a.ledColor'"
$ adb push preferences_storage /data/data/com.fsck.k9/databases/preferences_storage
That worked! I suspect that, on some level, certain color specs are not understood, and result not in a default color, but non-blinking-ness. What colors work and which don't? This could be determined, but I'm not about to send myself thousands of test emails.
I see at least two problems here: (1) There should be a default behavior for the LED. (2) The K-9 Color Picker needs to have some more flexibility, like a "safe" palette, or some fields for precise color specs with RGB or something. Come on Android world, come on.
Hope this helps.
