...the option is in "Sound & Display" option then select "Keyboard Timeout". The keyboard backlight & capacitive buttons seem to be tied together. Hope this info is helpful. Enjoy you Epic guys!![]()
Thanks for this info. I was wondering about this and will be important for the person I'll be getting the phone for.
I wonder if this would make the battery drain that much quicker or if the effects would be minimal.
probably pretty minimal. i plan on setting mine to match the screen, so 30secs. no need for them to be on allllll the time lol because when you light up the screen they turn on
Because you'll be double tapping all the time...
Hmmm...when I go to Keyboard Timeout my only options are to set time limits (3, 6, 15 seconds) or "same as screen timeout" - even with the "same as screen" it turns off when the screen is still lit after a while.
Thoughts?
It's not bugging me too much because like everyone said, you can just tap on it lightly to get it to come back on and you learn where all the buttons are, but it would be helpful to have them stay lit.
Thanks!
Why don't you just tap in that area when you need them lit?
When my screen times out, the screen becomes locked, and I have to hit the power button, and slide to unlock,. very annoying. Is there a way around having to do that?
