Keep iPhone or Wait?
bad1550
I have two weeks to return iPhone to Verizon. Should I return or wait for Galaxy 2? Coming from an Evo the iPhone is slower and just cannot see the tiny screen as well?
If I do return I will have no phone.
What do I do?
Thx
I moved from the G1 to the iPhone, a change I regretted so much that I cancelled my contract early so that I could get the Galaxy S2.
I have never looked back, the S2 in my humble opinion is simply the best phone / device that I have ever used or owned.
The iPhone is so crap compared to this or many android phones imo. Set up my sisters iphone last weekend and coming from an s2, I was a little embarrassed to show her my phone as it literally pisses all over the iphone. I think you know what I would advise you.
It depends how long you are prepared to wait - the iPhone 5 looks like it will be out in September.
I definitely wouldn't get an iPhone 4 now because the 5 will be out in a few months. I also think that the SGS2 is a much better phone than the iPhone 4. Who knows what rabbits Mr Jobs will pull out of the hat the next time but I have to say that the iPhone will have to make very substantial improvements to be better than the SGS2.
If you asked the same question in an iPhone forum it's obvious they may say something somewhat different :) We are a wee bit biased over here!
All I would say is the G2 is definitely the best phone in terms of hardware - if it's software you want then the iPhone is the place to be - but hopefully that won't last for too much longer!
I plan to return my iPhone 4 and wait for the newer phones, hopefully they will come out soon - either Galaxy S2, Droid Bionic or iPhone 5
Thx!
Bob
Just got the Galaxy S2 4G they call it here in canada. I had an iPhone 4 (had to change providers due to bad service where I moved) decided to try this phone. Seems like a real good phone. Battery life in iPhone was a bit better. Seems like pretty much all androids do not really do well with battery. Mind you I havent put the phone down and I have only went a couple of charges. People say it takes a few charges to get bettery battery life. This was also true with my iPhone. The Galaxy works no problem multi tasking. Its fast and so far have found no lag.
