Root Kernal HELP!!!
Did you download the koumamod.apk in the OP of the koumakernel thread?
If not, do so, and flash it in CWM. Then open it, allow it superuser access, and change it to Data, then reboot. If you have already started installing stuff before switching to data, it will more than likely start causing force closes and you may have to wipe the caches or reinstall (i just reinstalled the couple of times i've done it accidently.
ooh noo i did not do dowload that..ill do it soon. n i already installed apps :/... ima have to reset everything then flash that to work propperly? i dnt have a problem doin that lol
ok i did it plus it wasnt flashable since its jist an .apk download. but i got it thanks ATOT!!! :D :D i now have 435mb of internal storage :))
Sorry, i've not used it, so i didn't know exactly how to install. But you figured it out,so its all good. Grats on making your phone more badass :D
