Granite1
Zercron Encrusted Tweezer
I've got a few questions I'm not sure I have a good grip on here.
I've got hw 004, 2.15.00xx radio, 1.90_003 PRI, not sure what kernel I currently have. I assume its HTC #15
I was running myns rls5 with stock kernel for a couple of days, then I got the infamous 4g toggle issue. I tried everything to fix it, didn't work.
I then restored my original nand and went from there. Putzed for a day, then I noticed I was getting running 100% and screen on 99.9% under spare parts other usage. Weird thing is there was no huge eater under partial wake.
I then tried to run toastmod 4.3.1 cfs HAVS no sbc with my stock restore, I could litterally watch the battery % drain. about 1-2% a minute. I restored my original nand, things are stable, but my battery is still not lasting long enough. Max 10 hrs, with light usage and long idle times.
1.) Does a nand restore the kernel also, or am I still on netarchy?
2.) Should I downgrade my PRI and NV to 1.77? (heard this might be the culprit)
3.) I'm a little confused on the downgrading procedure. Should I flash the zip files I got from XDA in recovery? Or do I apply them differently?
I've read a TON, probably why I'm confused.
Myns ran tits until I got the 4g toggle issue. Good battery, fast and stable. Since then I can't get it to run right, battery wise.
As always ANY help is greatly appreciated!
