OK so do flash rom then kernel or kernel then rom? Also how do I now if the rom already has a kernel and which kernel will work with which rom? I'm looking to improve battery life.
You can find your current Kernel by going to "Settings", scroll down to "About Phone". You'll find your current Kernel listed there.
You'll want a Kernel that works with your ROM. You need to know if you have a SENSE, or AOSP ROM. Then make sure the one you pick is made for your ROM.
There are much more informed folks out there than I. Hope this helps...
