Root [Kernel]Blitzkreig+ Kernel by mtmichaelson
markolo25
Extracted from Broken out ROM V1.0, recently I just forked it and will be actively working on the kernel itself
The kernel features include
Code:
OC Kernel
Overclock CPU to 1.8ghz
First Boot is Set at 1.5ghz
Undervolted
Added Smartass2, Interactive, and Lagfree Governors
Added BFQ and VR I/O Schedulers
Added SLQB Allocator
Changed From JHash2 to JHash3
Added ZRAM Swap (To Turn on Use Terminal Emulator Type "su" to Gain Root Access, Then Type "zram enable" )
Added CleanCache
Added Frontswap
Added zcache
Added xz Decompressor
Included tun.ko
Upped Charge Speed
Other Memory and Performance Edits
Lowered WiFi Voltages
I/O Tweaks
Audio Tweaks
Many Other Speed and Battery Tweaks
just install on top of the stock rom however some of these features might not be usable yet since it may be missing some parts that was included with broken out, but from my end and a week of testing it seems fine even got to overclock to 1.5 stable no random reboots thus far, also bluetooth is working as I tested today in my friend's Volkswagen golf have fun ^_^ and hope I can get a working copy of 1.1 soon.
Remember BACKUP before flashing it's not my fault if your wifi breaks, or worse ^_^
DOWNLOAD
Very nice! been waiting for someone to do this. Broke my wifi tho so i will wait til you fix it before i flash again..
I have removed the lower wi-fi voltages, to see if it'll help i'll test then release if that fixes the problems
would you guys appreciate a flashable stock kernel for those with enough balls to test up the upcoming releases?
Sure.
