XDieAndGoX
** Disclaimer ** I am not responsible for anything that happens to your phone upon following the instructions in this tutorial. Though I am positive nothing should go wrong while doing so, it is always better to be safe. Do this at your risk.
WHAT YOU WILL NEED:
- ClockWorkMod [CWM]
Alright, so when I looked at This thread, the download link for the extracted Broken Out's kernel by MtMichaelson was not working.
Markolo25 is the first person to ever extract this kernel.
Anyways, I actually extracted it myself and, hopefully, I will be able to fix the few problems it has [e.g. Bluetooth Pairing], bur for now, I am giving you the kernel AS IS. This means no modifications, no new files. I, however, did copy all of the "system/lib" contents for the kernel to work at its best, so all .so files from "system/lib" and all of the modules in "system/lib/modules" are included in this Flashie.
The kernel should work perfectly fine on all current ROMs available for the Connect. For stock users, flashing this kernel will allow you to overclock and have all of the features the kernel offers in its native ROM.
Download Links:
BrokenOut's Blitzkrieg Kernel.zip [Mirror]
Steps:
Change Log:
- v1.2 - March 3rd, 2013.
- Finally fixed charging boot images! When phone is off, you will get to see how your phone charges instead of the weird black screen.
- v1.0 - October 11th, 2012.
- Unmodified original extracted release
WHAT YOU WILL NEED:
Download Links:
Steps:
- Copy the attached .zip file to your SD Card directory.
- Reboot into CWM and flash it over.
Change Log:
I also have been recently learning more about making ROMs and I have finally (and successfully) been able to decompile this ROM's boot.img to access all of its files; therefore, I was able to finally fix the infamous black screen that shows up when your phone is off and charging! I know BrokenOut is an old ROM and so is this kernel, but for those who like Blitzkrieg and the ability to overclock, this kernel is for you.
