txwolf1980
[EC07][KERNEL] Hacked Stock Kernel - xda-developers
This is a link to IMNUTS hacked kernel.
This kernel provides (depending on which kernel you choose from the page) 3 options, as well as a link to the stock kernel, in case you ever want to revert.
It is also the kernel used by Pattielipp in MIUNIA. While it isn't a true custom kernel, it has enough tweaks and hacks to enable script modifications to improve performance or battery life.
This kernel is a CWM flashable package.
Please click his thanks button, while you are there. And post any issues you have both here and there so other users can see your experiences.
One other note. since this is a kernel, and not a rom or theme, you will not be able to use a nandroid to revert if you have installation issues. So, please ensure that you have a computer with Odin and drivers installed available to reflash a stock kernel, if need be.
Thank you.
Thank you.
