Root Kernel for UltimateDroid 3.0.1?
Thanks, I'll give it a try.
If I run a 1.2 kernel and use SetCPU to limit it to 1.0 is it the same as running a 1.0 kernel? Makes sense, ya just never know... figured I'd ask!
Also, what's the rule of thumb with Kernels. If I run a 1.2 and as long as tempature stays low and OS is stable, am I good to go? Any other concerns?
Thanks again!
Thanks again!
the only real difference is that each kernel has 7 preset "slots" that it is capable of throttling to. on a 1.0 the presets would be 250,400,500,600,700,900,1000. on a 1.2 they would be 250,500,700,900,1000,1100,1200.
i don't even worry about temperature any more, just use the setCPU profiles to throttle back to 800 mhz at 55 degrees C and you will be fine. as long as it is stable, and it gives you decent battery life, keep it!
