Root Kernel Help needed please
gruss
Android Expert
tried to flash the Kingxkernel and the phone hung at the Htc Incredible screen. Now before you go all "then dont use it", I thought to myself "self, just flash back to the kernel you had before instead of waiting on a nandroid" and that did the same thing? No errors during the flash at all, so I restored all was well and tried a couple of other kernels I had successfully flashed the other day and they did the same thing!? so just restored again and thought I'd ask.
I have had this issue before on 2.1, as well as sometimes getting boot write errors flashing roms (with something other than a stock kernel) but like I said none of these kernels threw any errors whatsoever.
Any of you folks that are better at this stuff than me have any pointers? something I should wipe first, anything? I already tried different sd cards and stuff like that I'm just confused:confused:
BTW: running 3rd wave with the hydra ocuv-ov
This happened to me too, not sure the cause. i could nand restore the boot files to get back to my stock kernel but any other kernel i tried froze on the HTC screen. I had to do a full nand backup before flashing a hydra kernel again. also flashing a new rom made it so i could get the kernels to load again.
+1 would like to know too
Ok, I tried frankenRom and the install bombed, error writing boot. I wiped everything using clockwork! Well everything but the SD card, and when it booted only thing I noticed that was changed was the signal meter, still had txt, homescreen etc. Wtf? Tried a previous nand still couldn't do kernels so now um in tbe same place I was at noon. Really I want to know why this stuff bombs writing boot, and how I can format a partition in clockwork and yet all my data is still there? Might have to root the Eris and use that :P
Bump, no one? Anyway I installed skyraider vanilla without a hitch, gonna roll senseless for a while to see what the fuss is about. Was able to flash kernels, would love to know what is going on though, maybe phone just doesn't like some ROMs?
