Root Kernel help required!
d3310n
What is the fast kernel I can use that works with cm7 (latest) and will let me oc the highest? And what app should I use to of, i like no frills CPU for my LG ally but I've heard that app can't of me past 1ghz.
Edit: a link to the kernel would help even more :p
If your running CM7 then you don't need an app to overclock. Go to XDA, theres more info there than you can shake a stick at.
Well the Max with this kernel is only 925mhz (blehhhh) what rom/ kernel can I use to get up to these speeds like 1.1 and 1.3ghz I've been hearing of? Going to look at xDA right after this but a quick answer would help alot :)
