exgenmeikoj
Hi I'm wondering what kernels or modems I can flash with fl22
Main thing I'm looking for is battery life los (loss of signal) and the thing is I live in an Ares with no 4g and berly any sprint towers nearby there's a T-Mobile tower right across from the store so my 3g ether has low signal or no signal at all
Also on a second note my apps and android os would crash a lot
For exaample play store if I was to search or load a page the app will crash and lock my phone up then it takes like s min for it to soft reset it self.
Same thing with black Mart alpha
Then battery problems my phone takes forever to charge but is quick to drain the power out even on low settings battery saver and all I get maybe 4 to 5 hours
I'm running stock fl22 root minor con figs installed
And I have no emmc chip I ran the app from market would anyone have a suggested a safe recovery ? This build is touch wiz based BTW ice cream sandwhich
