Humanoid924
Nvm guys. I returned to stock and rerooted. Everythings great now. Awesome kernel btw. Thanks for all your time and effort in keeping this phone's development alive.
How'd you fix it? To help @papadog and anyone else who may need it... Or did you try to install on a custom rom?Nvm guys. I returned to stock and rerooted. Everythings great now. Awesome kernel btw. Thanks for all your time and effort in keeping this phone's development alive.![]()
What is your model number and android version?That didn't work for me.
Same as mine... Weird...SM-G386T
4.4.2
is it possible for you to send me a logcat ?Thank you for the reply. I tried flashing without wiping dalvik cache and cache first but it gave me the same issue. I read that wiping them could potentially solve the issue so I tried that afterwards and still have the same problem![]()
sorry for the noob question but how exactly do i do that??
AOSP in general, the only difference in roms as far as that goes is the ramdiskAre you working on a kernel for the aokp rom and if so how is that coming along.
Can't wait...lol...AOSP in general, the only difference in roms as far as that goes is the ramdisk
ok just an update I got it to work but I just wanted to know
if anyone has corrected the hotplug issue
I shall release a fix build for the screen issue... iam 99% sure i know what it isI am having issues with my cpu cores always staying online and rarely ever switching off and on. This is whether DVFS is enabled or disabled. Also doesnt seem to change much no matter which governor I use OR which hotplug I use. Alot of times the screen wont come back on, as if the min cpu speed is too low and I cannot change it no matter what I do. Its a good kernel but it would be nice if the speeds and hotplugging would work like it should. Right now to circumvent the screen power on failure I have dvfs enabled, hotplug set as mpdecision and using the performance governor that way the speed doesnt drop and keep my screen from coming on. Its a bit annoying as its eating my battery faster. Im not in any way putting the kernel down because, as the only TW kernel that I know of for this phone, I think it is a very good one! Anyone got any ideas?
Chuck
