GrandMasterBirt
Ok so I've been looking through the forms for metrics on kernel performance / battery life. Hard to find any list which is in any way "definitive".
Please reply to this post with ONLY the following information:
<possibility of an augmentation to a previous reply>
Rom - Version too Please
Kernel
Launcher
System apps which were removed
Performance - Subjective at times, note any slowdowns/speedups compared to other setups. Proof if possible.
Battery Life
Usage: (uptime vs active time, how heavy of a user are you). Usage can be determined by which background polling apps you have, how many hrs in a day do you use heavy apps like games/navigation (unplugged).
4G usage?
Locale / Tasker setup if applicable (if you see gains from using these)
Using SetCPU? vs no SetCPU (I hear SetCPU is bad for netarchy w/ HAVS)
Also an acceptable post is a response to another post claiming something is wrong, if that post is augmented and looks right, remove your post please.
If anyone has any metrics, please post! Proof is always welcome!
ALSO IMPORTANT: Post if you have a non-stock battery. Especially if it is higher capacity. I do want apples-to-apples comparisons if possible.
Kernel
Launcher
Battery Life
4G usage?
