steslatt Android Expert Oct 22, 2011 #2 Siyah Kernel 2.0 seems to work ok. There arent many that will work with it at the moment.
Shotgun84 Extreme Android User Oct 22, 2011 #3 What I was thinking. Its the only custom kernel that worked with cyanogen.
vtax Member Oct 24, 2011 #4 I had the stock kernel that came with then I updated to 1.10.21. But now I'm using xCell which is OK but I wanted more depth and battery life.
Blue1k Android Enthusiast Oct 24, 2011 #5 I ran xcell for a bit but found it a bit buggy with the newest build (galnet). The phone freezes when connected to a usb port. Siya 2 doesn't run that well on Galnet Miui 1.10.22. I'm hoping a newer Siya wil.
vtax Member Oct 30, 2011 #6 just an update... - updated to MIUI 1.10.28 (w/ stock Wolverine kernel) - installed Siya 2.0 (not 2.1 beta 15) - did a battery reset courtesy of xda forums everything seems to be running smooth. will do another update when i thoroughly test Siya 2.0
