Ok I want to be able to wifi tether and also overclock I'm running cm6 2.2 9/15 nightly and also is it the same process like flashing roms through recovery? Do I need to wipe? And I also heard something about a module do I need that?
Awesome thanks just one more thing could you send me the link to that kernel?
you can't flash the kernal with the nightly at the same time without rebooting?
dont need to do all that, justThe best way to flash the uncapped is right after you flash a nightly, then you won't have to worry about wiping Davlik cache and cache again.
Nandroid
boot into recovery
Wipe davlik cache and cache
Flash nightly
reboot
boot into recovery
flash uncapped kernel
reboot
Then use oc widget or setcpu to adjust the frequencies for your phone
boot into recovery
Flash nightly
reboot
thats what i was told to do, do it all in the same recovery session
Ok so does the kernel have to match up to a nightly or anything? or can any kernel work with any nightly?
I'm currently running nightly 9/15 and I got OC widget but i havent flashed a kernel yet.
so do I have to use a certain kernel for that particular nightly?
if you wipe, its gone, & always wipe before you flashCan you flash the same nightly over again or does the wipe get rid of it?
Where can I find the "module remover" that I must flash prior to flashing 710 kernal to improve speed on Fresh Rom? Looked all over but can't find. Thanks in advance!
