disciplexone
Simple Overclocked Kernel
This Kernel is for HTC Desire C GSM, thanks to cute_prince for first working OC and version disable check fixed to work properly by me in this kernel source . Special thanks to nikhil16242 for some advices.
Features:
Tweaks are from kernel source from showp-1984, DevChun , Adi_Pat, zarboz
Download 800Mhz NEW!!!
Download 767Mhz NEW!!!
Instructions:
Extract folder in archive to desktop
Connect phone to USB and Run the bat file
NOTE:
USB Debugging should be enabled in phone Developer Settings
You can customize kernel settings by downloading an app called SetCpu or NoFrills in Playstore. (root required)
Thanks and credits to the the names I mentioned in this post.
PS: Backup your current boot.img first in CWM recovery backup if this doesn't work you have a backup to restore.
NOTE: If phone becomes laggy after prolonged used just restart phone to refresh stability.
Source code
I made the source code as patch if you want to use this kernel
as base Download untouched HTCDEV Desire C Kernel source
here named Desire C-HTC-EU-CRC-3.0.16_v4.0_96.3 MB_2.00.401.3,
extract the kernel folder to your home/android folder in ubuntu
and apply the patch I made which will automatically modify all
files and subfolders to my Simple Kernel source. Download patch
To patch the source go to extracted desire c kernel in terminal type
cd /pathofkernel/golfu-ics-crc-3.0.16-51cada9
and apply the patch type
patch -p1 < ~/pathofpatch/Simple.OC.KernelSourceCode5.patch
you will see scrolling files patching, when it's finished
in kernel directory in file manager press Ctrl+H to make
the .config visible.
Features:
- Newly compiled from htc source 3.0.16 -51cada9
- Gcc 4.4.3 toolchain used in compiling
- Xz compression
- Vfs cache to 50
- Disable gentle fair sleepers
- O2 optimization
- lib/memcopy and string glibc version
- Enabled pipe compiling
- Makefile Arm7 optimization
- Tun, cifs, utf8 baked in zimage
- mm vm adjust ratio
- mm increase read ahead
- Vfp compile with neon
- Some compilation fixes by me
- Ntfs support
- Sha1 git implementation
- Arm rwsem algorithm
- patched upto 3.0.101
- 122-800Mhz OC Kernel
- Added new Governors, Smartass2, Lionheart, Lagfree, Interactive / old performance, conservative, ondemand included
- Added new Scheduler, sio / old noop, cfq, deadline included
Instructions:
NOTE:
Source code
