Austrie
Android Expert
SpeedDemon Kernel
Austrie's Kernel For MIUI
Using MIUI 11/25 build
Hit the thanks button and make sure to comment.
When this thread dies, I'll stop updating.
-Check ChangeLog In Second Post For Changes-
Features
Underclock
24576 (24Mhz)(0.02Ghz)
61440 (61Mhz)(0.06Ghz)
122880 (122Mhz)(0.12Ghz)
184320 (184Mhz)(0.18Ghz)
245760 (245Mhz)(0.24Ghz)
368640 (368Mhz)(0.36Ghz)
460800 (460Mhz)(0.46Ghz)
576000 (576Mhz)(0.57Ghz)
652800 (652Mhz)(0.65Ghz)
768000 (768Mhz)(0.76Ghz)
806400 (806Mhz)(0.80Ghz)
921600 (921Mhz)(0.92Ghz)
1024000 (1024Mhz)(1.0Ghz)
Overclock
1113000 (1130Mhz)(1.1Ghz)
1209600 (1200Mhz)(1.2Ghz)
1305600 (1300Mhz)(1.3Ghz)
1401600 (1401Mhz)(1.4Ghz)
1516800 (1516Mhz)(1.5Ghz)
1612800 (1612Mhz)(1.6Ghz)
1708800 (1708Mhz)(1.7Ghz)
1804800 (1804Mhz)(1.8Ghz)
1900800 (1900Mhz)(1.9Ghz)
2016000 (2016Mhz)(2.0Ghz)
2112000 (2112Mhz)(2.1Ghz)
2208000 (2208Mhz)(2.2Ghz)
2304000 (2304Mhz)(2.3Ghz)
Governers
Scary
MinMax
Lagfree
SuperbadSmartass
Ondemand
UserSpace
Interactive
InteractiveX
Powersaver
SmartassV2
Conservative
Performance
Smoothass
SavagedZen
I/O Schedulers
VR
CFQ
Noop
Deadline
Simple(SIO)
Anticipatory
~Extras~
Ext4
Slab
SVD
Swap
TinyRCU
Jhash V3
Cleancache
VDD Control
ZCache For EXT4
FileSystem Tweaks
Undervolt To 500mV
Updated 720p Drivers
Generic Sound Support
Faster USB Charging
Lowered WiFi Voltages
2-Way Call Recording
A Lot Of EXT4 Tweaks
Updated KGLS Drivers
ISO filesystem support
Disabled Kernel Debugging
Sony Bravia Engine Improvements
Cleaned Kernel Debugging Messages
Full Incredicontrol Capabilities
UDF CD-ROM filesystem support
Digitial Audio Brodcast Support
Frees Up Over 20MB Of Internal Storage On Phone
Allow CPU-Supported Unaligned Access
NTFS filesystem read and write support
Backwards Compatibility SupportPage Table Optimization
IPv6 Tracking Support
IPv6 Tables Support
USB Audio Support
USB IP Support
Zip Aligned Data
Much, Much, More...
___
Summary Of Govorners
(Only 75 to 90% Accurate)
Notes:
- Austrie Recommends the use of "Incredicontrol" app, "Startup Manger" app, & "No-Frills CPU Control" app from market!
- This kernel now contains the Isaac's fix for better HD gaming, therefor losing 30MB RAM.
- 2.1Ghz and above are EXTREMELY EXPERIMENTAL frequencies, I will improve them in next version.
- Undervolting frequencies higher than 1.0Ghz MAY causing bootloops.
- I have lowered the WiFi Voltages, and also Increased Volume; these are experimental. Watch these changes and report any bugs.
- I have increased USB draw amount/speed, meaning faster charging via USB Charging.
- There a couple volume boosters on market, "Volume+", "Volume Boost", and "SoundBoost"
- Make sure to recalibrate your battery, read this thread for info: http://androidforums.com/triumph-al...te-battery-better-accurate-batttery-life.html
- To 2-Way Call Record you need a separate app from market, called "CallRecorder" by skvalex, here is his DEV thread: [DEV] Two-way call recording on Desire [ALMOST SOLVED][Sept. 7 update] - xda-developers
- There is a DSP Manager for MIUI, link: DSP Manager Equalizer for Android - xda-developers
Features
Underclock
Overclock
Governers
Scary
MinMax
Lagfree
SuperbadSmartass
Ondemand
UserSpace
Interactive
InteractiveX
Powersaver
SmartassV2
Conservative
Performance
Smoothass
SavagedZen
I/O Schedulers
VR
CFQ
Noop
Deadline
Simple(SIO)
Anticipatory
~Extras~
Ext4
Slab
SVD
Swap
TinyRCU
Jhash V3
Cleancache
VDD Control
ZCache For EXT4
FileSystem Tweaks
Undervolt To 500mV
Faster USB Charging
IPv6 Tables Support
USB Audio Support
USB IP Support
Zip Aligned Data
Much, Much, More...
___
- Interactive: The interactive governor is functionally similar to the Ondemand governor with an even greater focus on responsiveness. In V5.0, it has been modified to save more battery, affecting performance by margin-able amount, while saving a lot of battery. Should be used as a starter along with SmartassV2, before using other governors.
- Smoothass: The same as the Smartass governor, but much more aggressive & across the board. Smoothass has about a third better battery life than stock. As far as I know this is a Smartass tuned for a more aggressive ramping, which means, more performance and snappiness, though less battery than Smartass.
- Conservative: It is similar to the Ondemand governor, but will scale the CPU up slowely to save battery, while still trying to meet demand. Conservative provides a less responsive experience than Ondemand, but saves more battery.
- Ondemand: When the CPU load reaches a certain point/thresh hold, Ondemand will rapidly scale the CPU up to meet demand, and then gradually scale the CPU down when it isn
