Motorhead1991
Android Expert
I downloaded the ZTE Blade kernel (2.6.35) in order to build a custom kernel for the ZTE Avail/Roamer, but I can't seem to find the text fine I need to play with the CPU. I also have a functioning zImage for the Avail, but can't decompile it (not sure which command will do that).
Here are my building tool specs:
Windows 7 starter (1.66Ghz CPU)
Cygwin w/ a bunch of script pkgs
Notepad++
Android SDK w/ minimal scripts
ZTE Avail w/ ARMv6 cpu (600Mhz stock)
I'm trying to gain voltage control and higher CPU settings. The zImage is OC to 864Mhz, which I am currently running. Where the files in the stock kernel that would enable these adjustments?
Notepad++
