Root Kernels for triumph
hayfit
Hey guys kindoff a newbie here. I've been trying different roms and all and never bothered with kernels so I don't know much about them. I've read somewhere that it's a bridge between softwares and hardwares so if that so what is the best kernel to install on the triumph. I have miui 2.4 thanks to the wonderful works of all the devs. Which one will do well for that rom? If it matters I like smoothness and longer battery I don't nessesaly need my phone to be over clocked. If possible can you guys give me a link to the ones you recommend so I can go see and try it myself. Thanks
For miui I think you have the mock kernel and speed demon kernel. You're going to have to try them out and see which one works for you. Mock kernel should be smoother it might be the rite one for you.
