Help Kes firmware update DKK4 from DJ3
Spine123
to all galaxy Y users....new firmware update from samsung for 2.3.6.
Just plug in your phone and open Kies. it will tell you of the new update instantlly.
Enjoy.
download from samsung site. go to touch phoes and select young.- support-download. and download latest kies version. it takes a lot of patience to upgrade ur phone to 2.3.6. remember do not move the position of ur phone once set.
Its available ,but whenever i try to update
first it takes a lot of time
Second the phones remain in downloading mode for hours but i hav no success
Is there another way to update
i want do update my phone but i get a error.
does anyone knows whats this mean?
new update is available and try 3-4 times after this fine to upgrade.newer is fine and sd card remove error does not appearing.
i tried kies but when i click upgrade when it start to download i notice at the bottom right saying "connection to S5360 has lost" even though it is not lost and i never disconnect it. tried 50times reinstalling 30times downling kies 10times = stil fail.
For those who have trouble connecting their Kies to their PC. Here's a piece of advice.
1. Uninstall old version of Kies using Revo uninstaller and remove all associated files.
2. Download and install new Kies (Dec 2 as of this post).
3. Launch Kies
4. Connect device to a fast USB socket (normally at the back of the cpu casing)
5. Download and apply update
P.S. DO NOT MOVE PHONE WHEN UPDATE IS IN PROGRESS!
When it fails, what you only have to do is close Kies and restart your pc. Open Kies again and reconnect your device. By then all should be well.
