Help Keyboard Repeating letters
Hey there. I friend of mine is also having this problem, and its driving her crazy. She has a Samsung Galaxy tab II, model GT-P3110, and she uses a Samsung dockable keyboard. I'm not certain about its model, I think it is EKD-K11AWEGSTD. I did an system upgrade using Samsung Apps and it is now running android 4.1.2.
I have tried to use the solution described in this post, but I'm not able to disable "samsung keyboard": gaebler.com/ Motorola-Verizon-Droid-Physical-Keyboard-Repeating-Letters-Problems. htm
I was wondering if installing some other keyboard (like swype, for instance) would fix the problem, but my friend is wary since all those keyboards do record her typing and do record credit card numbers and such.
I was wondering, could anybody give me any leads on how to fix this?
By the way, the weirdest thing just happened with the keyboard. It started inserting a bunch of blank spaces wherever I placed the cursor. Just as if I was holding down the space bar. Weird!
I am guessing that the solution for the droid is not going to work for your galaxy tab II. The droid was running GB and the galaxy is on JB. I am going to move this over to the galaxy tab II forum to get you some help on this.
