Help Keyboard Sounds
Writer14
Does anyone know how to turn off the typewriter sounds when using the keyboard. I know you can change the settings for this, as when I first got the phone I turned off the vibration setting whenever you typed a letter, and I'm sure I remember seeing an option to turn off the sounds as well. But now I can't find where I made these settings anywhere.
I think you can find it in settings > sound and it's at the bottom. Not 100% as i'm not using Sense atm but I remember it being around there
Edit: Actually you might find it in settings > language and input and then finding the HTC keyboard and look in the settings there. There is one which is like 'sound on key press' or something similar
