I just got the Galaxy S2 and I was wondering how do you disable the keypad sounds that are made when you dial a number?
The only way I have found is to uncheck 'Audible touch tones' in the Sound settings but that disables the internet keyboard sounds as well.
Is there a way to disable just the keypad dialing sounds?
