Help Keypad or Compact Qwerty advance cursor
burningembers
May 1, 2010
331
26
Portland, OR
Is there a shortcut to quick-advance when in keypad or compact qwerty mode?
On other implementations of this there is usually a key that makes it so you can quickly press the same key again and input that letter without it thinking you're double-pressing it and trying to cycle.
i.e. aaaaaa could be entered really fast if in-between each a i hit whatever cancels current input and advances the cursor.
(As an aside, any other keyboard alternatives that anyone recommends? I've tried BetterKeyboard, SmartKeyboard, Swype, Shapewriter, and ThickKeys - no go.)
Edit: Nevermind, I figured it out! If you hit enter it commits a key so you can quickly re-use that same key. Yay.
BEST TECH IN 2023
Smartphones
