kickstand, speakers
plim
Member
So silly question - you have to move the kickstand to expose the speakers.
does that mean if you want to use speakerphone or listen to music/videos with the external speaker, you have to hold your kickstand open?
kinda seems like a hassle...
NO should not have to. The speaker is a stereo speaker setup and I am sure the kickstand will not get in the way much.
If you're using the external speakers to listen to music, then you need to be flogged!! :p
Go heels
No. It will make it louder but there is no need. It will not dim the quality of the sound
That's actually a selling point for me. So flogged then.
;) I personally like those small speaker sets that plug in, although I like headphones even more for private listening. It helps drown out all the outside noise. The only problem with some of those real slick speaker mounts is they're typically made for iPhones.
