Help Kies won't work ):
I have a samsung Galaxy 5 because i wanted it for the andriods and apps. but i tried to dowload Kies with a CD i got with my phone and firts it worked after taking ages to download but once i was in the program it said i needed to update it, i declined but then if i tried to get into any of the things it said please update, once i tried to update after abou an hour it got to 703/704 and stopped. then when i got out of it and cliked into Kies it said Mainstage not working, click for problem solution so i did and it just said you may need to update your computer so i updated it all and atill it wont let me open the program. I then uninstalled and reinstalled the whole program this time updating when the first prompt came up the SAME thing happened agin after ages it got to 703/704 and now after leaving it a couple of weeks it still just says Mainstage is not working when i try to click into Kies. I have Windos Vista if that helps at all? pleaseeee anyone help me i hate not being able to do what i purchased this phone for :confused: :(
Tried on Windows XP, worked fine, tried on Windows Vista, problems again. I suspect it is a Windows Vista problem. About to smash the offending windows.
