Root Kind of a problem. [su access]
mrk
Hiya! I recently rolled back my phone, rooted via toast's method, flashed a custom rom (flipz) and radio, and removed Sprint's bloatware and boot noise. However, when I try to, say, run titanium backup, the request for su permission just hangs, and has to be force closed. The same thing happens if I manually open the Superuser Permissions app.
Anybody have any clue on how to fix this? Not much point in being rooted if you can't run apps that require root...
Go into settings, applications, development, and make sure usb debugging is checked. Then run it. You might have to reboot first and then check usb debugging.
