Help Kind of stupid question about how to switch from one call to another...
r4614
I can't believe I'm asking this super-basic question after having my phone for several weeks, but when I'm on a call and switch over to take a 2nd incoming call, how do I switch back to the first call when I'm done with the second? I keep hanging up on people! :confused:
Answer the second call as you normally answer calls. Then in the upper left corner of the screen you will see a manage calls button appear on the screen. Use it to bounce between calls. If the screen is off you'll have to turn it on to see it.
the screen should turn back once you move it away from your face. theres an IR sensor to the upper left of the LED for notifications. you'll notice when you answer a call it blacks out and when you pull away, if u look quick u can watch it go from blacked out and then to your screen turning back on
