Help Kindle Fire Won
This is another reason why I believe rooting/sideloading won't be as easy as people are assuming. In fact, it most likely will not be possible.
Amazon has rigid control over this device. It's not entirely their fault, but they have to in order to ensure it pays for itself. And to present an environment that appears to be as stable and secure as Apple's iOS.
The Fire is paid for by ads and end-user datamining. No, it is not $200 because they put cheap parts in it. Quite the contrary. They will not allow people to install their own OS, and potentially work around Amazon's only way of profiting from this tablet.
Yeah and I bet one of the reasons for "crippling" the API was to prevent root. I'd also be willing to bet that it will have a locked/encrypted boot loader. Judging by what I've heard thus far I won't bother with this device.
They crippled the API to improve performance. If you don't need things like GPS, BT and location services you can rip out the APIs that use them. Ripping them out gives you better performance.
I didn't even think of that, that's interesting. I just keep seeing people say that they removed some APIs, but if it doesn't use them, why include them? Especially if it'll improve the performance of the device.
Hopefully cyanogen gets to work on this tablet soon! I'd love to use CM9 over the heavily modified interface they have on it now.
Yup. There's no BT, so why include the BT stack? Then you can cut out all the APIs that would call the BT stack or monitor it. No GPS or location services so you cut out all of that and all the APIs that monitor those things. You go down the line and do the same with all the APIs you don't use. You get a stripped down machine, but better performance, therefore you can put your OS on cheaper hardware and it still runs well.
Amazon is providing a lot of value for the price with the Fire. It's primarily designed for delivering media. If you want something you can run whatever you want on then spend a little extra and get a Xoom or other tablet that has been on the market long enough for the price to come down.
IMO it at least needs to run everything in teh amazon app store, while that wont completely satisfy me cause of what will still be left out it will help since A Appstore is doing well for it self these days
But will it run all the apps on the Amazon Appstore? I understand the wall-garden concept. But it would be terrible if Amazon had to either segregate Fire-friendly (flammable?)apps into a sub-store of the tablet options in the Appstore. Even worse would be if Amazon cut all tablet apps that aren't Fire-friendly.
They set the bar a lot lower by dropping a lot of the sensors and the related APIs. They also retain a lot more control. Honestly, it feels like the fact that the Fire is Android is.... incidental. It's all about shortcutting their way to replicating Apple's walled garden, since they already have the media and the distribution network. Amazon is in a position to deploy heavily cloud based apps themselves (can't wait to see Silk), and for most of the core functionality, it sounds like they're planning on building and deploying them themselves.
I tried and side loaded Go Launcher Ex. It is at my 3rd party installed apps but not at my apps list on the device.
And I can't turn the amazon keyboard off in order to get Swiftkey running. Any ideas?
Yeah root it.
The fire will not let you use anything other than their keyboard other than by doing that.
Believe me, I have tried.
Yeah root it.
It's too bad the newer Fire's aren't more root friendly. The OG Fire is a pretty decent low end machine once it's rooted. The N7 is so cheap though that if you truly want a tablet, I don't know why someone wouldn't just buy the N7 instead.
