Nope, its still only on the nexus 5 at this pointHas anyone managed to get the OTA update for Kit Kat? Has it already been released?
Anyone know if the Google Services Framework trick works?
Is this the same as flashing a ROM? Do I just go into recovery and install from sd card? My N7 is not rooted, btw. Thanks in advance for the clarification!
can someone confirm that this can be used to update stock unlocked rom using TWM recovery?
I feel a bit robbed, it's nothing like Kit Kat on the Nexus 5.
Don't even have transparent task bar, I get the feeling this is more stock than 4.4 on the Nexus 5.![]()
Thanks... Ya I'm stock rooted with custom recovery. Download in now...
Will I need to reroot? If so what root will work?
