Downloaded and installed tonight pretty cool!
We may not need this one day cause I heard that Google has said that kit kat should be able to support all high to low end android devices. (not confirmed)
i couldn't get it to work on mine. " There is a problem parsing the package"
Are you running 4.1 JB or 4.0 ICS ? I believe the launcher only works on 4.1+.
the spirit doesn't run on JB
where you been??? I've had JB running on the Spirit since I got my hands on one. lol
you cant install like an app. you have to manually put it in /system/app
So these files will only work if you're running JB?
yea and well kitkat, lol, and the newer the better.
We need to push these with adb into system apps? I got a parsing error too when trying to install with package installer.
yea I used adb push blabla.apk /system/app/
Couldn't the subject use cwm to inject it into the system
I installed them on my phone as user apps and they all work fine.
