Kitchen Help
I am running Flipz 2.0 and am enjoying it but wanted to add back in some missing stock apps like Sprint Nav. Downloaded and installed Kitchen on two computers, Win 7 and XP, and can't get either to see my phone. USB Debugging is enabled, etc. Just can't seem to get it to work. Help.
Do you have htc sync installed? if so, and it isn't working, try PDAnet, There is a driver issue with sync and PDAnet can help sometimes.
I don't have Sync running on either computer. I do have PDAnet on the phone though. Should I uninstall PDA net for the time being.
I THINK you need htcsync on your computer, but not running for it to be recognized. not 100% sure, though. Try installing it and see what happens. I have both sync and PDAnet and it connects every time for me, but i have to pull down the not. bar and set it to sync, but not run the sync program on my pc
