Help Knock code
cosmia2
I like the way that you can use the knock code to go from phone asleep to home screen in one go. But the problem is that it often doesn't work first time and I need do the tap pattern two or more times for it to work. Anyone else have this problem? As far as I can tell I am using the exact same knock pattern each time.
Mine does it , I think its how hard you touch the screen when putting the code in , it might not register every touch , just an idea ......
I have no problem on my unit also but ever since 5.0.1 update i have been using smart lock & paired it with my lg g watch r so as long as it detects my watch I just swipe to unlock works real well
My phone is at&t d850 but I just switched to t-mobile but att they push by ota last Jan., I did not update till last 2 weeks ago I waited if bugs and security problems needed to be fix. So far so good, I do not experience other peoples problems like batt drain, lag or wifi issue.
