ringostarr1
I rooted my hydro and installed beats audio but now my sound does not work and my network went away it says no network and i have no bars!! and i dont know what to do any ideas!?
how do i do that do you mean factory reset button in the settings? ive tried that n no success i tried taking out the root with ES file explorer and succeeded but no help at all with the problem!I was afraid of something like this happening... without a working recovery like CWM.
At this point, the only thing I can suggest is to do a factory reset.
Let us know if you need any help doing it.
To all that want to root on the Hydro - it might be best to wait until one of us figures out how to get a working recovery on this phone.
I've been trying for days now, and quite frankly, I'm in over my head on this one.
Give it some time.... someone will crack it soon enough. We've waited this long... a little longer won't hurt.![]()
i tried that with the phone on and it took a screenshot and with the phone off in does not turn on at all when i try the volume down and power button although wen i turn it on and then hold the volume down and power button it shows the white kyocera screen then the boost screen and then it restarts and takes me back to the white screen and isn't there a way to use the kyocera system pull to fix it?Hold the volume down and power button at the same time.
Try that and let us know.
will that erase everything in my sd card??? and another question isnt that the same as using factory reset in the phones settings?Turn your phone off. Then press and hold both volume down and power buttons for at least 10 seconds... select "wipe data/factory reset"
i still wonder why my sound doesnt work even google voice typing it says audio error and shows ! that in a yellow symbolwill that erase everything in my sd card??? and another question isnt that the same as using factory reset in the phones settings?
well thank you anniedroid your a big help!! im going to give it a try! and when i installed it beats audio said when you uninstall this it will erase the beats notification icon not the drives and i didnt get that partIt shouldn't... but to play it safe (I would), pull your SD card after you turn it off. (before you factory reset the phone)
Sounds like something that Beats Audio did. It should work again after you reset.
yes and it says E:cannot load volume/misc and it took long to restart!! and the volume goes up and down now but still the same no sound and it says no service in about phone it says hardware version NV fail and Baseband version Unknown but still no successA factory reset should overwrite the BA drivers.
Have you reset yet?
From Kyocera's website;
"BRING UP THE SYSTEM RECOVERY TOOL
1. Remove the battery and return it after 1 minute.
2. Press and hold the volume down button (at the left side of the phone) then press and hold the power button. Wait for the front keys to light up and the Kyocera screen to appear. Release the buttons after that (you will see a large Android icon with the System Recovery Tool).
3. There will be three options on the screen; Reboot System Now, Wipe Data/Factory Reset, Wipe Cache Partition.
RESET THE PHONE
1. Press the volume down button until
Thank you for showing that im goin to try it and see what i come up with
i think im going to have to wait till a working recovery comes up its the same still it didnt work i still got the errors and no service in the bottomhey help me plz i cant make calls or recieve them it just stops my service
