Help lag fix, now stuck in force close loop.. help please!
howdy
Member
ooops.. the lag fix wasn't taking for me for some reason so I re-did the lag fix (probably a total of 3 times) and now I'm stuck pretty good.. I now know I should have did the unlagfix first, but I didn't think it did anything the first time since it was no different and quad was still 900.. so I did it again. I know, my bad..
So I'm stuck in a loop with errors for pretty much all applications (I'm assuming because there isn't enough memory now to run them??).
The first one I was getting is:
android.process.acore stopped unexpectedly
then it pretty well loops through all of the application and doesn't get out of the error message screen.
The application TwLauncher (process com.sec.android.app.twlauncher) has stopped unexpectedly. Please try again. (Force close)
I tried factory reset, didn't help. I did manage to connect to SD to reformat the card (which I'm doing now, although I'm doubting that will help any).
Is there an update.zip file I can flash??? or am I hosed?
The only way to possibly fix it is to get into recovery. I know the phone is in a loop, but maybe the phone will register on the computer for some point.
You can hook it up and when in adb, type in
Code:
adb reboot recovery
. I assume, you're familiar with adb since you tried to do the lag fix, right?
it's not letting me connect via adb anymore
Ouch. I'd just take it to Verizon. Hope they have the PST for Samsung and the file for the fascinate, or one on hand to exchange. Play stupid of course or make up a worthy excuse.
"I plugged my phone into my computer to transfer my music. After it finished, I unplugged it and it started to do this."
got it after reformatting sd, not sure if that had anything to do with it but it came up this time after the factory reset. guys might want to be careful until the recovery software rom manager or whatever is in place..
Did you end up fixing your phone? If so, what were your steps? I'm in the same boat, so if you were successful, it would be much appreciated!
Not sure if this will help you guys but I had someone remove the accuweather widget from the home screen and they stopped recieving the error. They have a Mesmerize...
