jimdriver2
Just wondering if anyone else is experienced this, and if so if they know of a fix.
Basically my widgets need you to be on a homescreen for a sec or 2 before they'll visibly respond to interaction. It's most obvious with powerstrip type controls (i'm using SwitchPro). If you press the Vibrate/silent/ring button it will change the phone mode (the icon changes in the status bar) but it won't update the widget.
I don't think it's the widget's fault, it's just the homescreens are running a little slow.
