jvbaseball
Iv'e been trying to work through this for a couple of weeks. Phone will lag (very long response times after I touch the screen 15-30 secs), freeze or on occasion just restart. Normally it does this if I'm using apps but not a specific one. The only way to fix it is to be patient and get it to do a restart or pulling the battery. It's done it will using several different apps or just using the search button at the bottom of the phone. I've been deleting apps thinking one of them is the cause with no luck, was using GO Launcher and now using Launcher Pro same thing. Any ideas on what I should be looking for before I break down and call the helpless center at Verizon. I'm unrooted and have not download GB.
thanks
Jerry
thanks
Jerry
