lapdock for triumph
breendrew
Member
I subscribe to Ben's deals and 1saleaday. I've recently been seeing lapdocks for various Motorola phones on there. Has anyone found a lapdock that would work with the triumph?
I may be completely wrong, but I don't think any of them are compatible with the Triumph. While our phone has the necessary ports, it lacks Motorola's lapdock software, which is used to load the actual UI and everything for the lapdock. Again, I may be wrong, so hopefully somebody else can verify this before you buy one.
I'd say besides what the person above said about not having the software id throw something else in there
speaking in just the terms of one that would Fit the triumph i'd say you have a 50/50 shot, ive seen probly 2-3 other motorola phones that are identical to the triumph in Every Single way except 1
the charge and hdmi ports are in different locations on all the other phones ive seen, and im guessing those are where it would connect
since i havent really seen to many triumph only accessories, id say,
If you could find another motorola phone that shares look and location of ports you may be able to find a dock for that model that would actually hook up to the triumph
but then if it does need software youd run into the issue mentions in the above post
if it didnt need software youd be good to go
well this all stinks...i'm seriously considering going back to a major provider. Kind of tired of dealing with all the generic crap on this phone Dammit
There was some guy on XDA that was working on making a stand for the device with the HDMI and Power connector. Last I saw he stopped as he moved on to another phone. However wouldn't hurt to try and make your own. You have a large community that maybe interested in purchasing such a device.
Hello, I'm interested in attempting to get the lapdock working with the Motorola Triumph.
I have a rooted Motorola Triumph, webtop.img, and a lapdock.
With a stock rom I'm able to get HDMI out with no keyboard, and no weptop app. I've attempted to install unverisal webtop app with no luck.
I'm new to Android and smart phones. I have experience with GNU/Linux and although I wouldn't consider myself a programmer I feel comfortable taking on the task.
Can anyone recommend some Android development articles?
Thanks.
hex3n
Thanks.
hex3n
well looks like you got all the hardware ready now just a matter of the software lets see maybe working it out one phase at a time will help far as the phone goes i think everything should be compatible with it i would suggest to maybe flash to a custom ROM a froyo ROM will be best since it will have HDMI working and evrything like stock and will give you more option to tweak stuff around idk if tweaking can be done on stock ROM since it will have limitations . what type of keyboard is it ? if is a bluetooth keyboard is a bit of a mess to get it working but is possible ..Not familiar with weptop can you install and boot ? maybe there is comp ability issues i will look into it what version you have ?
