Help Largest SD Card?
lazy3
Hi all new to the site aswell as Android, Cheers to the usb debugging tip but I was curious if anyone knows whats the largest SD card the DHD will support? Also is there anyway to remove stock apps w/o rooting?
Thanks
Ryan
Nah, you'd need to root to remove the stock apps unfortunately.
It will take a 32GB card, but if you buy one, make sure it's from a reputable retailer. Amazon/Play etc as there a lot of fake cards out there, especially on ebay.
Welcome to the forums 20GT.
I am unsure what the max size SD card for your device would be - you are more likely to get an answer relating to your phone from the sub-forum for your device Huawei Ascend - Android Forums (think this is the right one)
Hope someone in there can help you!!
