desert0mirage
Update: Completed this about 10 min after posting. Incredibly easy! If you can access this forum and can read, you can root and use SC. Give it a go UNC.
I had to flash the Super Clean 2.9 four times before it completed successfully.
The first three attempts hung part-way through.
"Super Clean version 2.9 - EB01/EB16 Froyo leak root+Froyo Clockworkmodwith MALWARE protection
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EB16SC29_DXC.tar"
2.9.1 patch (Requires 2.9, DO NOT FLASH IF YOU WANT TO KEEP LOCKSCREEN MUSIC CONTROLS!!!)
Voodoo and Nonvoodoo compatible
[URL="http://www.mediafire.com/?7g5yzakr5s778yx"]http://www.mediafire.com/?7g5yzakr5s778yx[/URL]
