Later made Vibrants better?
mystycs
Member
Is there a difference between those vibrants made at a later date than those earlier? Do they experience better battery? And are they less buggy?
Mine was made on 7/10 and I have experienced no bugs (at least that come to mind) and have seen a dramatic increase in battery over the last week.
Mine was made on 07/01 and it's been perfect aside from a few crashes and a little lag here and there and a couple of times the GPS didn't locate me in the correct spot but it was close enough but it's been spot on recently. I have a small gripe about the battery but maybe that's just me wanting a longer lasting one.
i have a question to all of you vibrant owners..!
please answer my simple question ..
are the volume buttons on the side of the phone loose or wobbly? coz mine is and it's annoying..
it works fine but it's just wobbly unlike the ones i saw in the store.. the one in the store was sturdy,but mine feels bleecchh..
please answer thanks..
Mine is sturdy. I would suggest that you exchange yours before your warranty ends, nothing worse then having it fall off after your warranty ends.
thanks so much!
ya im going to exchange it tomorrow...
this phone is gonna be with me for a year and a half or more and i dont want a phone like that.. lol.. this is my first phone from tmo too so i'd rather have the good unit one..
Like how loose is your volume rocker? I can rub my finger of it and it moves but it's not really loose.
These are pretty much my issues on my 7/02, except I haven't noticed the GPS problem. I get freeze ups, a few crashes, and a little too much lag, but either it is getting slightly better, or I may be getting used to it.:rolleyes:
As for your wobble question. The volume up and keys do not wobble in the up and down direction. however in the wrong direction, going horizontal, or left to right, there is a lot of wobble. I've noticed this on mine, and 3 other vibrants I've played with. There is a left to right wobble, I think that is normal.
i guess , i should save myself all the trouble since it is normal like you guys say.. thanks..
i'll keep it then..
