myfishbear
ive had luck with chevys low volt 1.0 ghz kern and the latest cyanogen7 nightlys. i use ti backup to remove any apps i dont use like voice or the stock email programs, the cm staststics, fota kill, anything that says cm lol except the cm settings app(including the cm market installer). personally i use the yahoo app... all together i get alot of mem free... i multitask well too... just remeber to clear your cache and davilik cache and factory reset when you install it... and also remember, first flash the rom, gbapps then the kern... if you still need memory disable android keyboard in the settings and you will get another 10 mb free at all times furthermore format your sd card, it may contain old cache files for you droid which will bog it down... after a day of use it should re write em and it will be much faster the second day and after...
new nightlies
CyanogenMod Mirror Network - Powered by TDRevolution
gbapps (google apps pack)
http://cmw.22aaf3.com/gapps/gapps-gb-20110613-signed.zip
chevy no 1 kerns
[Kernels] 5/31/11 - Froyo/Gingerbread
new nightlies
chevy no 1 kerns
