just got mine 2 days ago, GPS works all the time in less than 3 seconds , not many bugs, beside the volume low on the headset (around 60% of other phones), but get back to normal if you use the call function for some reason, BTW mine was manufactured in august 2011 and I buy it from amazon at $ 219 if that can help, and the little light on the bottom of the left screen is still there, but I can barely see it , thanks to the silicone cover....![]()
Well, I found a "fix" for the headphone "bug",
I start Pandora first, turn it off, go back to Power AMP and "magically" the sound is around 30% louder 'till you take the headphones...repeat as needed...![]()
Are there any date codes or anything to look for when picking them out on the shelf. I purchased the bestbuy 2 year warranty when got mine in July and might take it in and try to exchange it.
I actually just got a "newer model" as a replacement yesterday. The date on the back said it was from January of this year. Only problem on it is the light leakage and the bottom corners where the soft keys are at seem flimsy when compared to my broken Triumph. Everything else seems fine though.
