Root launcher has dissapeared?
If its 'clear default home' (built into LeeDroid) then that just sends you to the apps management screen that lets you clear any defaults set up.
What launchers have you installed? I'm running LauncherPro with no problems.
If the above doesn't work there is a new version of 'cleardefaulthome' free on the market called 'homesmack' try that.
