Help Launcher Issues with zeam
I recently downloaded zeam for my droid. when I hit the home button the option came up to use the stock launcher or zeam, with the check box to check off so the popup didn't come up again. I accidentally hit the stock option rather than the zeam option. Now when I try to use zeam as my launcher program, it works until I hit the home button then reverts back to the stock launcher. Any way I can get around this, and be able to use zeam? I already cleared data uninstall/install again.
Go to settings, applications, manage applications, find launcher, and hit "clear defaults". The next time you press the home button, you'll get that popup again, choose zeam instead.
