Launcher Pro and BobClock
ianramsden87
I can't seem to get the clock to display properly without it being on teh default amount of Rows/Columns
everytime I change the amount of rows then the widget isn't resized properly and ends up getting cropped at the top of it.
I've tried the autosize widget option in launcherpro /tna
Are you trying to resize to larger or smaller?
I use a themed BobClock (minutes smaller, hours fading towards bottom), and that works fine as long as I keep the actual size of the widget the same. So with 4 icon rows the default (2 rows high) works, whereas with 6 rows (what I generally use) I need to stretch it to 3 rows high before it displays properly. But as long as I do that, it works.
