Help Launcher Pro Custom Icons Keep Changing back?
kstuffer
Member
I change the launcher icons and they revert back after a day or so for some reason. Its only the phone, text and web launch icons though. anyone having this problem?
just select the icon you want to change as normal and this time select the option to change shortcut and from here select the one that you want of course and after it will give you an option to change the icon and now select the icon you want and after this it should not reset back to default.
