Root Launcher Pro Customization?
Blitzkri3g
So anyone knows how to get these circle shortcuts out of Launcher Pro app?
N.
Dont you guys know where can I find those icons which are used for Gmail, SMS and phone on the second screen from left ? o.O
I mean those white circles with items inside them :)
I am looking for his modded winamp widget :) it's so nice :) and what is that calendar widget ? It is awsome :) so simplistic !
I also loved the circles but I don't think they are buttons, just screen indicators. But whatever they are, they're not LP.
i like that look thats why i create and customize icon and dock to look my phone like that
but not 100% the same
this is it! TRIBAL LOOK
thats my LP home screen
and if you want to see the whole phone
its look like this
guys RATE it...
This guy's for example are buttons. It's the dockbar with modded icons. So pressing one of the buttons doesn't change the screen.
http://i277.photobucket.com/albums/kk57/leoair55/snap20110208_182528.jpg[/IMG]"]
its look like this
http://i277.photobucket.com/albums/kk57/leoair55/se-x8-xperia-frontcopy.jpg[/IMG]"]
guys RATE it...
Instead of ratings what do you say you explain to us whats the way to get this look? LP & which icons pack?
N.
The buttons work, but as regular LP. They are app shortcuts. The first LP mode presented here has screen indicators instead of apps.
Got it its launcherpro
Longpress on any dock icon
Change shortcut
There would be option for homescreen
Yes but the options are next or previous homescreen, not specific number. (like firs or fourth) So still not convinced it's LP.
